Hi Luis,
I loaded the 3.0 plugin for v5. The file with UI did not load at all, both local and remote. The file without UI loaded to 93% and stopped.
Dave
Hi Luis,
Dave
Hello Dave,
Had you tried the plugin before v 0.3.0? Did it work?
In any case, what kinds of model are you trying? Do they have textures and maps?
Finally, what is your computer environment (I assume from above Rhino 5 x64)?
If we cannot sort things out in this manner, I suggest we try a Skype or similar. It would help me to see where things are going wrong.
Thanks,
Luis
v 0.3.0
On RH5 - worked ok both with and without UI.
On WIP - error message:
Rhinoceros WIP Failed to Save Failed to save as [path]\[name].webgl. The file writing plug-in failed.
Thx.
Same here.
No error message on save.
And no visible output.
In Chrome, the UI loads but not the model.
All I get is the âIris art projectâ when trying to do something with the right mouse button:
CP_WebGLArt.mp4 (129.6 KB)
Hello Charles,
What is this video? Where do the arrows come from?
The video is the Chrome window.
It opened after âExport selectedâ.
Donât know where the arrows come from.
I thought you should knowâŚ
If you want to have a look, skype me.
Thanks,
-C-H-A-R-L-E-S-
Hello All,
Iris has been updated to 0.3.1, now with support for Blocks and their nested objects. Still to work on are exporting dimensions, hatches, text dots, clipping planes, etc. If you have a block heavy file, Iâd appreciate you test it out and let me know how it goes.
Thanks!
Luis
Hello All,
Iris has been updated to 0.3.2. This adds support for materials set by layer. Points and Pointsets have been reworked to work better with the layers in the WebApp.
Thanks,
Luis
Hello All,
Iris has been updated to 0.3.3. This release fixes some issues in both the WebApp as well as the Plugin side of things. Most notably:
As always, this is a WIP, so any feedback you have is important to getting this working well.
Best,
Luis
p.s. I am always compiling against the latest versions of Rhino so currently:
Hi Luis,
double sided rendering would be good:
-C-H-A-R-L-E-S-
Thatâs fair. It is not so difficult to turn on. There are some issues with shadows looking right, and this is why I turned it off. Iâll switch it on in 0.3.4 and see how we do.
Hi Luis,
Thanks for the update agian!
An Issue I have been wanting to report is that it is not possible to overwrite a previous save.
When in the save dialog and choosing the previous export, you get directed into the previous saved folder.
Not sure how this would be solved, but since itâs a folder that is saved, itâs impossible to overwrite that.
Thanks
-Willem
Well, there could be a few ways to deal with that, but none of them have peaked my interest as a great approach.
It is too much trouble to just delete the previous save or create a new folder? Iâd like to know in which cases something like this would be a critical feature?
Hi Luis,
Itâs not much of a problem *), just an annoyance as itâs counter intuitive given the way it works when saving a file with extension:
I have found a workaround:
If I type the name and add â.Webglâ the export will overwrite the previous export.
This brings another issue to light btw: should there not be a warning about overwriting?
For me, Iâd prefer a folder type export as opposed to a package.
Maybe a local option would be package in any case, Itâs indeed much easier to distribute.
Another issue I found while testing this:
If I exported with local option I cannot delete the folder! Apparently ârhinoweb.exeâ keeps running in the background preventing the deletion of the folder. Even of the browser has been closed.
Thanks!
-Willem
rhinoweb.exe closes down if the tab in the browser is closed. For some reason, if the whole browser window is closed, it misses this event. Iâve added this as a bug to be fixed immediately. soon Thanks.
HI Luis, I having an issue with when I create a .webgl file. Then try to open it, it will start to load in my browser then stall at roughly 80%.
THanks!
Dave
Dave, @sierradays
Is it with all files? Which browser are you using? Try this, once it stops loading press F12 in the browser to get the browser console and press F5 to refresh. Are there any errors that come up in the console window?
thanks,
Luis
Hi @fraguada
Today I installed iris-win.0.3.3
for Rhino5
I get an error message when starting Rhino:
DETAILS:
DETAILS:
Any ideas?
-Willem
I had it installed but got the message that the 0.3.3 version expired. There is no new version. . .
