str="15 apples"
int=method(str)
Result: int = 15
What’s the Rhino Script method, if there is one?
str="15 apples"
int=method(str)
Result: int = 15
If you had this:
str = "15"
You could do this:
val = CInt(str)
http://msdn.microsoft.com/en-us/library/0zk841e9(v=vs.84).aspx
But because your string contains non-numeric characters, the problem gets harder. Natively, VBScript has no function to extract numbers from a string. But if you search the Internet, you can probably find numerous functions that search for numeric characters in a string using a regular expression (Regex).
