As an example of a topic with the intent of sharing a script I present this script:
Description:
This script will allow for multiple curves at once to be extended (or shortened) smoothly on both ends.
a negative Extension Length will shorten the curves.
Tags:
Extend Shorten Multiple Curves
wd_ExtendCurvesSmooth.rvb(1.3 KB)
When drag-dropping the script over Rhino it will automatically register an alias equal to the filename (without extension) Example: ScriptfileName.rvb will create the alias ScriptfileName
So you can change the filename at will. Do make sure the file remains in the folder you initially drag-dropped it from.
Option Explicit
'Script written by willemderks.com
'This work is licensed under a Creative Commons Attribution-ShareAlike 3.0 Unported License.
'Script version Wednesday, May 15, 2013 11:20:43
'this script will allow for multiple curves at once to be extended (or shortened) smoothly on both ends.
'a negative Extension Length will shorten the curves
Call Rhino.AddAlias(Split(Split(Rhino.LastLoadedScriptFile, "\")(Ubound(split(Rhino.LastLoadedScriptFile, "\"))), ".")(0), "!_NoEcho _-Loadscript " & Chr(34) & Rhino.LastLoadedScriptFile & Chr(34))
Call Rhino.Print("Alias " & Split(Split(Rhino.LastLoadedScriptFile, "\")(Ubound(split(Rhino.LastLoadedScriptFile, "\"))), ".")(0) & " added to Rhino")
Private OLDdblCurveSmoothExtension
If isEmpty(OLDdblCurveSmoothExtension) Then OLDdblCurveSmoothExtension = 1
Call Main()
Sub Main()
Dim arrCrv : arrCrv = Rhino.GetObjects("Curves to extend", 4, True, True, True)
If IsNull(arrCrv) Then Exit Sub
Dim dblLength : dblLength = Rhino.GetReal("Extension Length", OLDdblCurveSmoothExtension)
If IsNull(dblLength) Then Exit Sub
OLDdblCurveSmoothExtension = dblLength
Call Rhino.EnableRedraw(False)
Dim i
For i=0 To Ubound(arrCrv)
Call Rhino.ExtendCurveLength(arrCrv(i), 2, 2, dblLength)
Next
Call Rhino.EnableRedraw(True)
End Sub
HTH
-Willem
PS
Can anyone tell me how to properly create a syntax highlighted code block that does not wrap lines?
