Creating a hollow solid object
You can do this in Rhino with polysurfaces. It is generally not recommended, since the result may not behave as expected in other Rhino operations, but should be fine for your purposes.
Make the inner and outer polysurfaces. Call NonmanifoldMerge selecting both, Call CreateRegions on the result. Delete the inner region.
Chuck Welsh
Robert McNeel and Associates
