I want to match surface number 1 with surface number :
2(G2)
3(G1)
4(G0)
5(G2)
At first i match surfaces 1&2(G2)then if i want to match surfaces 1&3(G1) my match between 1&2 surely destroy ? or have change type of continuity (for example G2 transform to G1)?
Hi Shayan- If surfaces (e.g.1 &2 in your image) are mirrored copies, matching for tangency and āaverageā set will get you a very good G2(Curvature) match with minimal changes to the input surfaces.
If I had to guess, Iād say majority of those who ask elementary questions here are using pirated software. In case of those using Matrix or other hyper expensive plugins, Iād say the pirate percentage goes upwards of 95%. Surely, someone must be buying those software for the companies to stay afloat, but whenever contractors or students send me files with such identifiable data in them, I automatically tell them that they are using pirated software and that I wonāt deal with them. None of them have ever protested.
I wish McNeel employed an authentication mechanism so that in addition to providing free software to pirates, they did not provide free tech support as well. It takes focus away from the needs of legitimate users.
That is an utterly unfounded statement, in any evidence that I know of. I wonder what on earth leads you to such a statement. Many beginners ask questions here and we welcome and encourage them to do so, The forum is for novices at least as much as for experienced users.
If you look at Zebra before any matching youāll see the surfaces are very nearly G2 already - in other words the third row of points is already nicely positionedā¦ Matching for tangency cleans up the first two rows. I do not see a problem hereā¦ ?
I assume that you know how virtually different between G1 G2 on Zebra.
You cannot make G1 to G2 by simply adjusting mesh settings.
āLook closeā term only uses in G2 or above continuity. Thatās because you cannot or extremely hard to distinguish G2 and above curvature continuity by simply looking at Zebra or curvature graphs.
You might ask for your brother in Italy get a Rhinoceros. In that case, the God might help you.
