Hello! Any reason why the countour label does not reflect the actual height (z value) of the point? It shows 350 but it should show 150… Thanks.
Check the document geolocation. It is possible that you have set the coordinate origin elevation to 200, so that z=150 means 350 . You can check it in the document properties, under the Geolocation tab:
Thank you, completely overlooked that.
