I am once again struggling with my rhinoscript and have already searched the whole internet for a solution of the following problem.
I need to store data in a nested array. The data consists of strings which are devided into max. 300 groups. Each group consists of max. 100 strings. I would like to define a nested array with dimensions in the following bounds: arrStrings(0 to 300)(0 to 100).
The problem is, that I have to write the strings to the array one after the other in a loop. Reading a single element of the array is easily done by e.g. Rhino.Print arrString(51)(45).
I tried a similiar syntax to set the values of the elements, but this approach didn’t work, e.g.: arrString(51)(45)=“Test”.
Sub Main()
'initial array
Dim MyArray
MyArray = Array(Array("A", "B", "C"), Array("D", "E"), Array("F", "G", "H", "I"))
Rhino.Print MyArray(2)(0) 'prints F
'Assign new value
MyArray(2)(0) = "Test"
Rhino.Print MyArray(2)(0) 'prints Test
End Sub
Is there a convenient way to assign the initial values of the array in a short syntax? Assigning the values in the shown way in case of a array with 300 x 500 = 150000 values would be crazy
Hey, we are talking about 1000 lines of code and the nested array is deep inside of several loops. It wouldn’t help if i post the whole code. Instead i will try to explain what I am trying to do.
The script will be used write to several csv-files which will be used to export & import the compartmentation of a ship (rooms inside the hull) to an other calculation tool:
Each layer in Rhino represents a comparment. The name of the layer is written to the csv-file.
Each compartment is build together from multiple spaces. Each space is defined on its own child-layer. The names of the child-layers are also writted to the csv-files.
Each space is defined by multiple faces/planes which are defined on the child-layers.
The script consists of the following loops:
1st loop-level: loop through compartments
2nd loop- level: loop through spaces
3rd loop-level: loop through faces
Because the comparment/space/face-information have to be sorted and structured before writing them to the csv-files, i have to save them to an array. Thats why I am trying to use a nested array:
The first index will be used for the spaces (up to 300).
The second Index will be used for the faces, which belong to each space (up to 100 per space).
Here is a basic sample to assign and retrieve items from a 2 dimensional array using loops
Sub Main()
Dim i, j
Dim arrNames(10,5)
For i = 0 To 10 - 1
For j = 0 To 5 - 1
'Assign value to an array item
arrNames(i, j) = "N" & i & j
Next
Next
For i = 0 To 10 - 1
For j = 0 To 5 - 1
'Print array item
Rhino.Print arrNames(i, j)
Next
Next
End Sub
There are additional utility samples that you might find useful here:
Here is a sample to create jagged array dynamically. Hopefully this comes closer to what you need
Option Explicit
'Script written by Rajaa Issa
'Script copyrighted by Robert McNeel & Associates
'Script version Tuesday, May 25, 2021 11:14:30 AM
Call Main()
Sub Main()
Dim MyArray()
Dim SubArray()
Dim len, i, j, b
'x = length of 1st dimention of MyArray
Dim x: x = 4
ReDim MyArray(x)
For i = 0 To x
'len = length of 2nd dim array for each row up to 10
len = 1 + Int(Rhino.Rnd * 10)
ReDim SubArray(len)
For j = 0 To len
SubArray(j) = "A-" & i & "-" & j
Next
MyArray(i) = SubArray
Next
'Print valuse
For i = 0 To x
b = UBound(MyArray(i))
For j = 0 To b
'Print
Rhino.Print MyArray(i)(j)
Next
Next
End Sub
