I get this error:
Message: 'ascii' codec can't encode character '\u43A' in position 37: ordinal not in range(128)
Using this method - Writing out a dictionary object
# encoding:utf-8
import csv
def CSVwrite():
#Get the filename to create
filter = "CSV File (*.csv)|*.csv|*.txt|All Files (*.*)|*.*||"
filename = rs.SaveFileName("Save point coordinates as", filter)
if( filename==None ): return
dict = [
{'Floor':'1', 'Use':'Хол', 'Square Footage':'6598', 'RoomID':'100'},
{'Floor':'1', 'Use':'Детска', 'Square Footage':'1900', 'RoomID':'101'},
{'Floor':'1', 'Use':'Кухня', 'Square Footage':'1850', 'RoomID':'102'},
{'Floor':'1', 'Use':'Баня', 'Square Footage':'250', 'RoomID':'103'},
{'Floor':'1', 'Use':'Килер', 'Square Footage':'150', 'RoomID':'104'}
with open(filename, "wb") as csvfile:
fieldnames = ('Floor', 'Use', 'Square Footage', 'Price', 'RoomID', 'Capacity')
writer = csv.DictWriter(csvfile, fieldnames=fieldnames)
writer.writeheader()
for row in dict:
writer.writerow(row)
# Check to see if this file is being executed as the "main" python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
if( __name__ == "__main__" ):
CSVwrite()
Good that you found a working solution.
