But what I need to read and write isn’t attached to any particular object. So, if I understand correctly, I need to work with the Document User Data. Is there an example for this somewhere? Something similar to the cs_userdataCommand but for document rather than object data?
I was able to get Dales c# sample working. The harder part for me is converting to VB.net and adding it to my project and then understanding it to the point that I can tailor it for my own needs.
For each of the two namespaces, I used a converter to get the VB.net equivalent, then added a class to my project and copied in the converted code. Is this the proper way to do it? Or should I be adding a Rhinocommon command and then cutting and pasting into the command? On a side question, I no longer seem to have the option of adding rhinocommon commands, how do I get that back?
I then get an error for the OnLoad function for the following lines:
Rhino.RhinoDoc.NewDocument += New EventHandler(Of DocumentEventArgs)(AddressOf RhinoDoc_NewDocument)
Rhino.RhinoDoc.BeginOpenDocument += New EventHandler(Of DocumentOpenEventArgs)(AddressOf RhinoDoc_BeginOpenDocument)
Did they not convert to VB.net properly or am I missing something?
In truth, I am a bit overwhelmed with this project as there is lots of stuff going on I don’t get. Perhaps there is a dumbed down version with just the essentials to understand reading and writing plugin data to 3DM files?
Just to let you know where I’m heading with this, I want to save a bunch of doubles to 3DM files, perhaps a couple hundred, and will likely want to use a dictionary to do it.
Thanks, that simple method is something my feeble mind can understand
I would like to call the setstring function when the document saves and the getvalue when it loads. What is the simplest and most straightforward way I can do this? I think Dale’s example was doing this, but once again, over my head…
'Value defined somehwere else
Protected Overrides Function OnLoad(ByRef errorMessage As String) As Rhino.PlugIns.LoadReturnCode
AddHandler Rhino.RhinoDoc.BeginSaveDocument, AddressOf BeforeRhinoCloses
AddHandler Rhino.RhinoDoc.EndOpenDocument, AddressOf EndOpenDocumentRhino
Return Rhino.PlugIns.LoadReturnCode.Success
End Function
Private Sub BeforeRhinoCloses(ByVal sender As Object, ByVal e As Rhino.DocumentEventArgs)
RhinoDoc.ActiveDoc.Strings.SetString("Key", Value)
End Sub
Private Sub EndOpenDocumentRhino(ByVal sender As Object, ByVal e As Rhino.DocumentEventArgs)
Value = RhinoDoc.ActiveDoc.Strings.GetValue("Key")
End Sub
I think something like this
but your plugin should run before this works. So it will starting to get the info after the first command is triggered. Its also possible to force rhino to load the plugin when rhino opens.
2nd but. This is an “easy” way out. The one from Dale is a “deeper” code that will write a string table as document data.
I tried adding the code to my plugin class, but for some reason my plugin doesnt load anymore when I start rhino. I was having the same problem when I was trying to get a VB version of Dales sample working. Any idea what the problem is? Below is the code.
Thanks,
Sam
Namespace PodoCAD
'''<summary>
''' <para>Every RhinoCommon .rhp assembly must have one and only one PlugIn-derived
''' class. DO NOT create instances of this class yourself. It is the
''' responsibility of Rhino to create an instance of this class.</para>
''' <para>To complete plug-in information, please also see all PlugInDescription
''' attributes in AssemblyInfo.vb (you might need to click "Project" ->
''' "Show All Files" to see it in the "Solution Explorer" window).</para>
'''</summary>
Public Class PodoCADPlugIn
Inherits Rhino.PlugIns.PlugIn
'Shared _instance As SampleVBPanelPlugIn
Public Sub New()
Instance = Me
End Sub
''' <summary>
''' The only instance of this plug-in.
''' </summary>
Public Shared Property Instance() As PodoCADPlugIn
Get
Return m_Instance
End Get
Private Set(ByVal value As PodoCADPlugIn)
m_Instance = value
End Set
End Property
Private Shared m_Instance As PodoCADPlugIn
' You can override methods here to change the plug-in behavior on
' loading and shut down, add options pages to the Rhino _Option command
' and mantain plug-in wide options in a document.
Rhino.RhinoDoc.ActiveDoc.Strings.SetString("Key", 10)
End Sub
Rhino.RhinoApp.WriteLine(Rhino.RhinoDoc.ActiveDoc.Strings.GetValue("Key"))
End Sub
''' <summary>
''' Is called when the plug-in is being loaded.
''' </summary>
Dim panelType As System.Type = GetType(PodoCADPanel)
Rhino.UI.Panels.RegisterPanel(Me, panelType, "Sample", System.Drawing.SystemIcons.Question)
End Function
''' <summary>
''' The tabbed dockbar user control
''' </summary>
Public Property UserControl() As PodoCADPanel
Get
Return m_UserControl
End Get
Set(ByVal value As PodoCADPanel)
m_UserControl = value
End Set
End Property
Private m_UserControl As PodoCADPanel
End Class
End Namespace
I think that’s all for this topic. I have another question that is somewhat related to this, but different enough that I’ll ask it in a separate thread.
