Workspaces for OSX
Is there a technical limitation that prevents supporting Workspaces on Mac?
Hi Pharris -
Do you mean Worksessions?
If so, according to RH-36512 there are 3 dependencies, two of which have not yet been resolved.
Apologies for “autocorrect” - yes Worksessions…
Where can I see the dependencies? Currently only
SDK RhinoCommon: Worksession class needs work
is visible for me.
RH-49556 SDK RhinoCommon: Worksession class needs work
That actually depends on RH-36512, not the other way around.
But yes, I thought that all links would be shown and that one then gets a 404 when one tries to follow a private link. That doesn’t seem to be the case.
I’m not sure if this implies there is any active development towards supporting work sessions in OSX
The only thing I see that implies such is the release target of RH-36512 Worksessions not implemented
That was moved from “Future” to “9.0” a month ago.
Ok, without getting in the weeds of the various Jira’s etc, from a customers point of view what is the plan wrt either WIP or Prod timeframe (or lack thereof)
I’m afraid that the only information that I have is what is in RH-36512.
It looks like there currently is an intention of getting this into 9.0. Apart from that, (1) that might change, and (2) nobody here knows when 9.0 will “happen”.
Understood.. With the (changes in the) way OSX handles Auto-Saves, beyond any reasonable size model (>5G-ish), Worksessions seems to be (one of) the only ways of having a reasonable workflow.
