Wish: Subselection copy to clipboard
Hi…,
it would be nice copying subselected objects to clipboard.
Thanks
Michael
www.flexiCAD.com
Would be useful.
Currently I just do gumball drag with Alt key to get it copied…
As you can duplicate egde, or extract surface as copy , what is the goal to copy subObject to clipboard ?
I think just less clicks and no commands that need to be called (besides ctrl/cmd+C), if one has a regular habit of working with sub-object selection, it might be more muscle-memory favorable…
A bonus might also be able to copy a collection of discreet curves/surfaces plus edges, sub-curves and sub-surfaces all at once to the clipboard in the same operation.
–Mitch
PreSubselect work with extract surface and dupegde ( only 2 edges for me in V6, and normaly in V5) may be a bug in V6
Edit : Seems to work in V6 , but sometimes somes edges are not duplicated, strange.
but i’m not sure you’ll have less clicks, as what has been copied should be pasted , select > copy > paste or select > extract for the same result
Seems like a logical and expected behavior if ctrl/cmd+C just can copy to the clipboad.
Also if you want edges and surfaces, it’d be less steps than extractsrf and dupedge at a time.
:+1:
yes please
it should be possible to subselect a face for example and then copy-paste it to another document as surface.
same for edge to be pasted as curve.
@Gijs my guess you would agree - i count on you !
Interestingly this was just discussed the other day internally, I agree!
RH-60049 CopyToClipboard subobjects - follow the Copy command
