I think it would be more useful if SelKey worked like SelName, meaning it would bring up a list of all the keys in the document & let you click on one to select those objects.
(Obviously, I can write my own script for this, but it seems like this is how the built-in command should work.)
Hi Peter -
Now on the list as RH-64468.
Hi.
I think we stuck a little with @Trav answer on YT thread.
I believe selecting from panel allows to select objects with limit of keys from current object.
The idea is to be able to see list of UserText keys and values for whole file. And to select those objects.
that’s correct
That’s indeed the goal of the listed request. As far as I can see that is clear.
