[wish] Sections update on Apply button click
Hi @rajaa , thank you for lot of useful updates on sections!
I have a wish: to update the clipping drawings from Section Style dialog not immediately but by clicking “apply” button. Now changing hatch scale from 1 to 100 made wait long twice - on value 10 and on 100
You are welcome!
So while you are still in the SectionStyle Dailog, changing the scale updates the drawing, and you’d like that the update take place only after you click OK on the dialog? Did I get that right?
Running an example at my end, the drawing only updates when you hit OK in the SectionStyle dialog. Please give an example to clarify.
Ah, I see now: the geometry is really updated on OK, but after I type each digit in Scale field Rhino stuck for a bit.
@Trav might have an explanation?
Id need a file, a version number, a system info dump to provide any real answer but it sounds like the dynamic preview of something in the section style is causing you lag (hatch, linetype)? A heavy unoptimized hatch pattern could have this affect, but it wont be limited to section styles.
