Could you please add the option of baking only the final output of a cluster, instead of all the geometry inside it, as it happens now. (and maybe set this option to default, as it feels more logic)
Thanks!
Thanks!
Would it make the most sense if the baking was tied to the same setting as the preview? I.e. if you can see the geometry inside the cluster it will also be baked?
Well, not necessarily. Imagine a cluster that does some parametric rooms and calculates the areas for them. I would like to see the area so I can adjust the design, but once I bake, I don’t want to bake the text of the areas.
I see. Logged under RH-43831. I’m not sure when/if this will happen for GH1, but it’s there at least for GH2.
