hi all, I am working on airflow file for butterfly and I tried to add weather data to the file which means “wind speed and wind direction” but I don’t have a node in butterfly to figure out them.
also I used ladybug too use wind speed and direction from it but it’s not working also
so I have a question what is the difference between location and other if I can’t use weather data for my location? maybe I have a conflict
hi! were you able to solve this problem? if so, could you please share with me how… i’ve run into the same issue and am having trouble finding a solution…thanks!
