Love the fields, statistics and function heavy potential of G2.
I am curios to know if this is being done in anticipation or along with current trends in AI, statistics and ML etc.,
However, I having some issues working with fields, A major barrier is not being able to merge merge fields so that I can apply the field to multiple - say 1000’s, or hundreds of 1000’s - of points/breps/geo/vectors or whatever at once, like I can in G1. Issue is runtime complexity - I could graft objects and test all field values / charges against that object, and try to map the value based on proximity to other objects, but but it does not scale well. (thanks for the help file - this is where I read about runtime complexity).
Copying in the component from G1 does not work:
I thought there may some ‘other’ approach taken and I had a good search through other components thinking that I somehow merge a field into one object.
Will there be a merge Fields component for G2?
Will there be different ways to ‘merge’ as in break fields into discrete parts based on some ‘other’ functions or statistics?
Thanks,
Ark
Also / PS, I am getting some issues with cpu at 100% in small definitions. Deleting or disabling components seems to not help, I wonder if it is related to undo or something? this probably needs some examples and different thread.
