Why is there this hotspot in the middle of my screen?
V6 (shaded mode):
V5 (shaded mode):
Top view, the gray surfaces are all planar and parallel to XY.
Hi MItch - I see that as well in plan views… If I set the defaults, I get both the hot spot and the expected emap ‘horizon’
And, I do not see any of the default lights being the source either…
Try this:
Options > View > Shaded > Shading settings
Color & material usage: custom material for all objects
Customize…
x user objects’s display color
Gloss intensity: 0%
Gloss finish: 0%
Does that make it any better?
Yep, if I turn off the gloss, the hotspot disappears, and if I turn off the environment, the band disappears…
