Hi Viva -
Actually, no! Well trimming yes, some Join, but to finish the job In this case where you need non-manifold edges - where I originally thought you were making a ‘physical’ model and needed to add thickness to avoid the collisin that you actually want for the FEA mesh - so the command isNonManifoldMerge is the one.
The inputs were not quite as precisely lined up as needed -if the result is what you want, I’ll make you a file with some details.
