What is the reasoning behind allowing a tolerance of ModelAbsoluteTolerance * 2.1
in pythons JoinSurfaces method? Is this the tolerance for the Join command as well?
I ask because I’m scripting the Brep.MergeCoplanarFaces(tolerance)
method and want to set a tolerance in order for it to work as expected based on tolerance settings.
Do I best set a tolerance multiplied by 2.1 as well? Brep.MergeCoplanarFaces (ModelAbsoluteTolerance * 2.1)
Thanks
-Willem
def JoinSurfaces(object_ids, delete_input=False):
"""Joins two or more surface or polysurface objects together to form one
polysurface object
Parameters:
object_ids = list of object identifiers
Returns:
identifier of newly created object on success
None on failure
breps = [rhutil.coercebrep(id, True) for id in object_ids]
if len(breps)<2: return scriptcontext.errorhandler()
tol = scriptcontext.doc.ModelAbsoluteTolerance * 2.1
joinedbreps = Rhino.Geometry.Brep.JoinBreps(breps, tol)
if joinedbreps is None or len(joinedbreps)!=1:
rc = scriptcontext.doc.Objects.AddBrep(joinedbreps[0])
if rc==System.Guid.Empty: return scriptcontext.errorhandler()
if delete_input:
for id in object_ids:
id = rhutil.coerceguid(id)
scriptcontext.doc.Objects.Delete(id, True)
scriptcontext.doc.Views.Redraw()
return rc
