What is the method of connecting two perpendicular objects using screws and nuts through slots and tabs? I want to search up some best practices, but I don’t know what to search for. Thanks!
I also use this with laser cut steel plates, I recess the “male” part a bit, then I weld into the recess on the backside and grind flat. It avoids the weld bead in the inside of the “T” and is more likely to assure a true 90° joint.
May I suggest: the joinery shown is mortise and tenon, with or without added screws.
T-slots are undercut dados meant for a sliding fit.
Your table saw probably has a t-slot in the surface, a pair for sliding a crosscut sled.
Your woodworker bench is probably joined with mortis and tenon style joints.
amirite?
that’s one way to use a t-slot.
however, outside of the woodworking shop, i think you’ll find more cases of t-slots being used as a means to avoid welding, tapping, and/or provide a modular solution.
or, in the woodworking shop, look at Festool’s track saw for an example of two types of usage… you can use the slot to slide clamps to match your workpiece… or, you can use the slot to fuse (non-permanently ) two lengths of track into one.
edit-
do a google image search for t slot construction
