What is this component?
Hi there,
I’m trying to do some edge boundling and wanted to know the circled component. Is it a data dam?
Much appreciated and thank you very much :slight_smile:
It’s a relay. You can create it by double clicking a wire. It helps keeping the definition clean when you need to plug the same output into many inputs far away from the original component.
Perfect. Thank you :slight_smile:
Thanks, please click the solution box.
