What is page viewport?
Rhino documentation ( https://docs.mcneel.com/rhino/6/help/en-us/properties/viewport.htm ) says: Three viewport pages (model viewports, page viewports, and detail viewports) contain information and controls that are relative to that viewport.
What is the page viewport?
Hello - Page refers to the layout page.
Can you give an example or definition? Is layout page the same thing as the page viewport?
Model viewports are what we know as top, front, perspective etc
Page viewports are what we know as a layout pages.
Each layout has a viewport, you zoom in and out of a page for example
Detail viewports are the views onto the model onto a page layout.
Does this make sense?
You are confirming that layout page is the same thing as the page viewport. I believe that the layout viewport is also the same thing.
A screenshot would be helpful.
I would say that detail viewports are the views into the model from page layout (a.k.a. layout page; a.k.a. page viewport; a.k.a. layout viewport). I believe that detail viewports and details are the same things. I suggest that the word “page” should be expunged from Rhino documentation, unless it means physical piece of paper.
https://wiki.mcneel.com/rhino/layouts5
Ever since layouts were intoduced the term Page and Layout have been a cause for confusion. There was never a descision made what their definitive name is.
My take:
They are LayoutPages, problem solved.
A LayoutPage is what you get when you create a new layout. You see a white page with possibly a number of details on it.
That what displays that LayoutPage ( a 2D view that only pans and zooms) that window is the Page Viewport.
In short expunging Page is not going to happen.
Just always when reading Page or Layout either add Layout in front of Page or add Page after Layout.
…LayoutPage…
Does this make sense now?
@KelvinC LayoutPage is fine with me. If we always call it LayoutPage, we can call model viewports just viewports, and we can call detail viewports just details.
This Rhino documentation page: ( Viewport properties | Rhino 3-D modeling ) describes three kinds of Viewport Properties: Model viewport properties, Layout Viewport Properties, and Detail viewport properties. If we call model viewports just viewports, then we have to rename Viewport Properties. We can call them Space Properties: Model Space properties, Layout Space Properties, and Detail Space properties.
I’ll change page viewports to layout veiwports.
On Windows, layout is layout viewport. On Mac, there is a single layout viewport that contains all layouts (layout pages).
When we say viewports, it usually means model viewports.
When we say details, it usually means detail viewports.
Same with layouts and layout viewports.
In some cases, we ues model viewports, layout viewports, and detail viewports to reduce confusion.
That will be a huge change to documents (web pages, wiki, training guides, help topics…), command names, option names… It’s not likely going to happen.
It seems that the best way to end the confusion is expunging the word “page” from Rhino documentation, unless it means physical piece of paper.
https://dictionary.cambridge.org/dictionary/english/page
I searched “page” in the whole Rhino help project. No more “page viewports”. All the other “pages” in layout related topics look fine to me. If you see any “page” that causes confusion, please let me know.
Active toolbar shown in the following screenshot has nothing to do with the layouts, but it is called Viewport Layout.
viewport%20layout
There are five page words related to layouts in this file: https://docs.mcneel.com/rhino/6/help/en-us/commands/layout.htm
There are ten page words related to layouts in this file:
https://docs.mcneel.com/rhino/6/help/en-us/commands/print.htm
There are seven page words related to layouts in this file:
https://docs.mcneel.com/rhino/6/help/en-us/commands/new_viewport_arrangements.htm
“Viewport layout” means how veiwports are arranged. There is also “Toolbar layout”. They have the same concept with layouts for print.
Thanks, but they don’t seem to cause confusion as “page viewport.”
