Way to select/insert all block definitions defined on x layer and change them to correct layer?
Hi everyone!
  • I am currently working on a team of a couple of people, utilizing block definitions inside Rhino.
  • I often encounter layers that I do no need, but do not get purged because a block definition was defined on that layer.
  • My workflow to deal with this is, try to delete layer>get name of block that is defined there>insert command>find block name>insert it> double click to edit>change layer on which block lays.
This is already a very time cosuming workflow for a simple task, but what is worse, when you try to delete the layer, Rhino does not name all block definition that are actually there, it tells you one at a time. So if you change the layer of one block and try to delete the layer, you then get a new message telling you there is another block on that same layer!
How can I deal with this? I was thinking a script that could identify all blocks that are defined on x layer, insert them, and change them to a correct user defined layer… Is this possible?
Thanks in advance,
Shynn
Any ideas if this is possible?
Hi @ShynnSup,
This sample script dumps the contexts of a instance definition:
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinopython/SampleDumpInstanceDefinition.py
You can modify this to get the definition object’s layers too.
– Dale
Hi @dale
I get following error when running the script :frowning: :
File “C:\Users\Shynn\AppData\Local\Temp\TempScript.py”, line 49
SampleDumpInstanceDefinition() # Call the function defined above
SyntaxError: expected an indented block
Hi @ShynnSup,
The script works here in Rhino 6.
It’s a simple error - make sure intending is correct on that line…
– Dale
Great, it run. Seems that Ctrl + C and Ctrl + V into Rhino PythonEditor deletes that indentation.
Not sure what the script is doing though, what do you mean by “dumps the contexts of a instance definition”? Can you help me modify it to change the layer of definition of all selected blocks?
