VS C# - The object default preview disappear after implementing "DrawViewportMeshes"
Hi all,
I am trying to wrap-up a component In Visual Studio - C# but when I implement “public override void DrawViewportMeshes(IGH_PreviewArgs args)” to preview the plane vectors the default shade for Srfs disappear.
        args.Display.DrawDirectionArrow(_OriginDirDisplayA, _zDirDisplayA, Color.Blue);
        args.Display.DrawDirectionArrow(_OriginDirDisplayA, _xDirDisplayA, Color.Red);
        args.Display.DrawDirectionArrow(_OriginDirDisplayA, _yDirDisplayA, Color.Green);
        for (int i = 0; i < _xDirDisplayB.Count; i++)
            args.Display.DrawDirectionArrow(_OriginDirDisplayB[i], _zDirDisplayB[i], Color.Blue);
            args.Display.DrawDirectionArrow(_OriginDirDisplayB[i], _xDirDisplayB[i], Color.Red);
            args.Display.DrawDirectionArrow(_OriginDirDisplayB[i], _yDirDisplayB[i], Color.Green);
Also I try to implement this code to get something similar to the default preview but only works for the C# component in GH not in VS, but the result is not as good as the default shade, it hides the vectors when look form below:
public override void DrawViewportWires(IGH_PreviewArgs args)
       for (int i = 0; i < _srfXXXs.Count; i++)
            args.Display.DrawBrepShaded(_srfXXXs[i], _material);
            args.Display.DrawBrepWires(_srfXXXs[i], Color.Red);
Any suggestion how to get the default shading in VS?
Best
Iker
base.DrawViewportMeshes
Thanks Keyu,
where should I implement this?
best
Iker
    base.DrawViewportMeshes(args) // <---- Here
Thank you Keyu!
Now all works !
also found an example of base.DrawViewportMeshes(args) in this old post:
Ones again Thanks!
Keyu I see you are base in Hangzhou, I am based in HK.
Just added you to Linkdin in case in the future there might business opportunities specially with talented people like you.
best
Iker
