"Voussoir" Stereotomic design plugin for Grasshopper
Voussoir — Grasshopper Plugin Release (v1.1.0)
Hi everyone,
We're excited to share the first public release of Voussoir, a Grasshopper plugin focused on parametric stereotomic vault generation and voussoir-block modelling.
What Voussoir does
Voussoir introduces a set of tools designed to:
  • Generate base vault geometry — create base surfaces for barrel vaults from simple guide lines/curves (springer lines + vault profile).
  • Divide vaults into voussoirs — automatically subdivide vault surfaces into spanwise and lengthwise voussoirs, defining intrados planes, contact surfaces, and longitudinal/transversal division planes.
  • Generate solid voussoirs with intrados, extrados and contact surfaces — suitable for modelling or fabrication.
  • Generate springers (trapezoid or wall-based) based on the vault geometry and the voussoirs closest to each springer line.
The aim is to make vault design more parametric, intuitive, and fabrication-ready inside Rhino/Grasshopper.
Components
Component Role
BVSrf Base vault surface: define springer lines + profile → vault surface
BVDivG Vault division: create division grid for voussoirs
VoussPlnr Solid voussoir blocks from division planes
SprT / SprW Springer generation (trapezoid or wall-based)
ArcH / CatH / ParH Utilities: create arc, catenary, or parabola by height
Who it’s for
Architecture studios, students, heritage researchers, digital-fabrication workflows.
If you design vaults, stereotomic geometry, or block-based masonry — Voussoir aims to speed up your process.
Learn more at: https://stbim.arq.up.pt/voussoir_gh/
Get it now
Install via Rhino’s Package Manager → “Voussoir”
or download from → https://www.food4rhino.com/en/app/voussoir?lang=en
Future plans
  • Additional vault types (groin, ribbed, etc.)
  • Parametric joint & block-pattern control
  • UI improvements for streamlined vault design
Feedback, bug reports, or feature requests are welcome.
This plugin is one of the products of the research on steretomy, of which you can also visit this page: https://ssc.arq.up.pt/
