Hi everyone,
Can you please indicate the best approach to create velux windows on a VusualArq roof and be classed as onjects in the schedule.
Thank you!
Hi everyone,
Thank you!
Hello @antonia.gregoriana,
You would need to create the gap manually in the roof using the _vaSubtractSolids command. Windows cannot be created tilted, so maybe you could create a Grasshopper style as a vaElement with the geometry of a velux window.
If you are not a Grasshopper user, you can create it using Rhino blocks, also as a vaElement, following this workflow: https://www.visualarq.com/support/tip/how-can-i-create-customized-doors-or-windows/
