Hello @fsalla,
Please review the results below of the DWG export from the layout using the new VA3 export feature. The curves are not at the same heights. Thank you, Tomas.
Hello @fsalla,
Hi @tcisar you are right! we will revise this issue for future updates.
+1
vaExportToDWG, then opening the dwg in Rhino again:
Thank you, Francesc!
Are you planning to remove vertical lines in the process? Meaning those that would project to a point in XY.
