Hi @stevebaer,
there is a small buglet with PointSizeMillimeters, the helpdoc states that it allows Double
but a value of 1.4
is always reverted to r="2"
in the svg file.
some future wishes:
Could you please make Point objects pay attention to Print Width set in Properties as it is the case with curves ? Currently they are written as <circle>
nodes in the svg but their stroke-width seems hardcoded to 1
. It would be helpful to control this for points which are rendered with larger radii.
Could you please add a property to ViewCaptureSettings so object ids are written to the svg file ? This would allow to detect objects in Rhino and perform all kinds of customisations to add or change node attributes before saving. Currently, objects are not easy to detect as the node order in the svg seems to be arbitrary.
Since svg is now the way to go for toolbar button icons in R8, what are the plans to support hatch gradients when capturing svg files ?
Btw. big thanks that circles are finally written as <circle>
nodes in R8.
_
c.
