I created tags for my doors, they show up in the perspective view and parallel projection, but the border shape disappears when I press toggle cut plane. Is this a known bug or is there a solution to this problem? Trying to change the elevation of the tag didn’t work.
Hi @martijn.voz,
I’ve been able to reproduce the issue.
Here is the latest build of VisualARQ 2.13.2 with this bug fixed:
http://visualarq.s3.amazonaws.com/download/visualarq-2.13.2.17562-rhino7-setup-snapshot.msi
Thanks for reporting the bug!
Enric
It seems to work as expected now, thanks!
Hello Enric!
I tried to install 2.13.2.17562, but get this error when starting Rhino:
I uninstalled the previous version beforehand.
Thanks!
Hi @Eugen,
I’m looking into this issue, but apparently, McNeel accidentally broke the Rhino C++ SDK in Rhino 7 SR32. This means some C++ plugins may fail to load in SR32. I’ll report the issue so they can fix this ASAP.
In the meantime, the only workaround is to downgrade Rhino 7 to SR31. Here is the download link:
https://files.mcneel.com/dujour/exe/20230615/rhino_en-us_7.31.23166.15001.exe
I’ll keep you posted as soon as I get more information.
Regards,
Enric
The bug has been reported to McNeel.
Sorry, but we cannot fix this issue on our side.
Enric
RH-76240 is fixed in 7.32 Hot Fix 1.
Hi @enric,
I’m having this exact same bug in current release of VA3.0.4.18256 / R8.4.24044.15001. Any clues how to fix it?
Thanks!
-Clay
I could reproduce it as well. We will let you know when it is fixed.
Thanks, Alfonso! Glad to hear it wasn’t just me.
@Clayton_Muhleman bug fixed in the VisualARQ 3 Beta 5 version: New VisualARQ 3 Beta 5 released! - #6 by enric
