hello everyone, is only with me or VA plans add ups to 100mb on the file (small apartment around 90 m²)?
Hi @Leonardo_G_Pate,
If you refer to a plan view object created with the vaPlanView
command, the size of the 3DM will increase, since this object creates a block with all visible lines.
But this behavior was already like this in version 2. Can you send me the file you are working on, to visualarq@asuni.com, so I can check that there is no bug in version 3 that would cause the files to be too big?
Thanks,
Enric
I know that it got the file bigger in VA 2 but I found this size increase now more dramatic.
Also, when I import a template its not coming with some 2d blocks, only their 3d representation
I’ve fixed an issue that solves the file size increase. It will be available in the next Beta.
Enric
@Leonardo_G_Pate the new Beta is out! you can try that issue of the file size increase and confirm it’s fixed.
! Thanks man, the whole community appreciate! hope the official realease is near! keep going!
Hi francesc! About the VA3 release, what should we expect? more few months or couple weeks?
I can’t say exactly, but it will take 1 or 2 months still.
thanks!
