I’ve made some tools to make working with V-Ray more productive. reflectLight and moveLight don’t depend on V-Ray
Also I made a toolbar.
The RUI points at d:\scripts\VRay so if you want to store your scripts elsewhere, you will need to modify the toolbar.
Please feel free to use, and hopefully give me some feedback for improvements.
Most is documented in the scripts. The tools are:
customRes: to set a custom resolution through command line. Useful to quickly set often used resolutions through a button (first toolbar icon uses this to set A4/A3 size)
changeRes : to scale a resolution by a factor. I use this often to switch the resolution to half or double size (second button uses this to either increase or decrease by factor 2)
swapRes : to swap x and y resolution (in other words toggle between portrait and landscape)
reflectLight: place a (rectangular) light by its reflection (this is in its infancy, because it will modify the distance to the object)
So therefore I also have this tool:
moveLight: move a light in the direction it is aimed at
note: The reflectLight tool will work for spots and for rectangular lights + it doesn’t alter the shape of the spotlight like _EditLightByHighlight does
I don’t know, but I realized I uploaded an old rui, can you try again?
Other than that there should be no major differences with the scripts I shared previously through Chaosgroup discourse.
sorry, I don’t know why you get this error. There are a few threads here that are related to .rui files not loading, maybe these help? If I download the file it opens correctly here. Did you use the Clone or download button on github and then unzip the package?
