Using variables in Rhinoscript rs.Command()
What is the syntax for using variables in rs.Command()?
Here is a sample of what I have been trying to do:
p1 = rs.GetPoint(“First point”)
p2 = rs.GetPoint(“Second point”)
rs.Command ("_Line" p1 p2)
This works:
p1 = rs.GetPoint("First point")
p2 = rs.GetPoint("Second point")
rs.Command ("_Line " + str(p1) + " " + str(p2))
p1 and p2 are Point3d objects, you need to turn them into strings to get them to be read at the command line. You also need spaces at the right spots.
But, why bother? Just use:
rs.AddLine(p1,p2)
Much simpler!
Thank you.
