Hi there,
maybe someone can help me. I got the new Rhino 9 and wanted to test the built in AI Panel. Now I tried adding Gemini AI, since I have a paid subscription (AI Plus) and would like to use it. But I cant find a way to add it it seems.
Hi there,
Hi @lukaskirschnick,
The AI panel in the current Rhino 9 lists Claude and Codex only. Gemini is not available in the panel’s agent drop-down at this time, so there’s no setting to add it there.
You can still use Gemini with Rhino 9 through Gemini CLI, which talks to Rhino over MCP:
MCPConnect. It prints the command Gemini CLI needs to launch the Rhino MCP router.mcpServers section of ~/.gemini/settings.json, using --default-version 9.rhino server should then show up when you list MCP servers.Step-by-step details are here: RhinoAI – Gemini CLI
Other MCP-capable clients can point at the same router as well.
– Dale
