Use TrimBrep
Dim strObject, strCutter
strObject = Rhino.GetObject("Select surface or polysurface to trim")
If Not IsNull(strObject) Then
	strCutter = Rhino.GetObject("Select cutting surface or polysurface")
	If Not IsNull(strCutter) Then
		Rhino.TrimBrep strObject, strCutter
	End If
End If
It’s always trim in I don’t like. The same picture 2. But i want to cutting in " Want to trim" the same picture 1.
I don’t know about it. Please help me.2 1
Just one post, please.
– Dale
When I use SplitBrep it creat 2 parts of the surface. But i don’t know identifier of 2 parts. Please help me.
Dim strBrep, strCutter, d
strBrep = Rhino.GetObject("Select brep to split", 24)
strCutter = Rhino.GetObject("Select cutting brep", 24)
d = Rhino.SplitBrep(strBrep, strCutter, True)
Rhino.DeleteObject(d)
I want to delete 1 parts of “d” which created from splitBrep.
Hi.
if strBrep and Strcuter created from AddLoftSrf or AddSrfPt… then it is not successful.
But StrBrep and Strcuter = Rhino.GetObject(“Select”) then it is successful.
. Please help me.
Hi @cua54kttt,
Does this help?
Sub Main
	' Local variables
	Dim strCutter
	Dim arrBrep, strBrep, arrPoint
	Dim arrPieces, strPiece, strDelete
	Dim arrCP, dblDistance, d
	' Pick the object that cuts
	If IsNull(strCutter) Then Exit Sub
	' Pick the object to trim
	arrBrep = Rhino.GetObjectEx("Select brep to trim", 24)
	If IsNull(arrBrep) Then Exit Sub
	' Make sure the same object wasn't picked
	strBrep = arrBrep(0)
	If strBrep = strCutter Then Exit Sub
	' Get the selection point
	arrPoint = arrBrep(3)
	' Split the object with the cutter
	arrPieces = Rhino.SplitBrep(strBrep, strCutter, True)
	If IsNull(arrPieces) Then Exit Sub
	' Find the piece that is closest to the pick point
	dblDistance = 100
	strDelete = Null
	For Each strPiece In arrPieces
		arrCP = Rhino.BrepClosestPoint(strPiece, arrPoint, True)
		If IsArray(arrCP) Then
			d = Rhino.Distance(arrPoint, arrCP(0))
			If (d < dblDistance) Then
				dblDistance = d
				strDelete = strPiece
			End If
		End If
	Next
	' Delete the trimmed piece
	If Not IsNull(strDelete) Then
		Call Rhino.DeleteObject(strDelete)
	End If
End Sub
– Dale
