Does somebody know if it is possible to set a control Tooltip showing up with a certain delay?
My problem is that the tooltip in my panel shows up within 2 seconds approximately, but I need it to be faster.
Thanks in advance,
Emma
Thanks in advance,
Emma
Hi @Emma_Bizzotto,
There’s no API in Eto to control tooltip speed, but on Windows/WPF you can use ToolTipService.InitialShowDelay and macOS you can use something like this, translated to C#:
NSUserDefaults.StandardUserDefaults.SetInt(1, "NSInitialToolTipDelay");
However, I’m not sure if this is a system wide setting or just for the running application, so it might not be a feasible option.
Another option is to create your own tooltip with a non-activating borderless Form then you can have full control over its timing and content using UITimers.
Hope this helps,
Curtis.
Hello @curtisw,
Thank you very much for your answer. I think I will follow your suggestion to create a tooltip using a non-activating Form, I did not think about that.
Emma
