Hi, I am using linked block in a file and find out that after editing material in a linked file, the object in a main file remains as it was inserted first time.
Image above shows the main file on the left side and linked block file on the right side.
Both files should look same but not.
main.3dm (71.5 KB)
block.3dm (39.6 KB)
- If I change the block type to embed, it works normally
- I checked “Rendered” and “Raytraced” view and neither of them works
Is it a bug?
Any clue will be helpful.
Thanks.
