It works, but to undo it I have to undo twice, once for the orient3pt and once for the paste (and usually I forget the second one, so I end up with unwanted stuff in my model).
There’s a simple way - without scripting - to “atomize” my alias so that only one undo is needed?
(use the above as your alias / macro). This way one undo should do it all.
Basically any macro you paste between “…” there would work that way, unless your macro has some double quotes on its own, then it gets a bit more complex with using multiple double quotes ; )
Thanks Jarek (and thanks to everyone else who answered). This does exactly what I wanted (and it’s quick, not loading any script), and is a powerful trick too.
