I’m trying to select an object by ID but when I go into ‘Manage Element Collection’ and add an item it won’t let me double click to add the ID value. Instead there is a warning saying “This item cannot be edited by double clicking”. What am I doing wrong? I’m using the latest RC version.
So that worked. But then what is the element component for?
As mentioned here, it should work. @scottd @eirannejad
You are right. It is documented as that. I use Element node to connect outputs of custom python components. It makes it much more readable.
Thanks for reporting. I filed a bug report.
