Unable to run compute-rhino3d locally using local computer as server
I was following Junichiro Horikawa’s tutorial on how to set up compute-rhino3d locally, and it was not successful.
What I did:
  1. download and unzip the latest build compute-340 from this link.
  2. set the following environment variables:
    COMPUTE_BACKEND_PORT = 8080
    COMPUTE_HTTP_PORT = 8888
    COMPUTE_HTTPs_PORT = 0
  3. ran the following in PowerShell as admin:
C:\WINDOWS\system32> netsh http add urlacl url=“http://+:8080/” user=“Everyone”
URL reservation successfully added
  1. and, ran the following, too:
PS C:\WINDOWS\system32> netsh http add urlacl url=“https://+:443/” user=“Everyone”
  1. then , after I ran:
    C:\Users\USER_NAME\Downloads\compute-340>compute.frontend.exe
I got the following which seem to indicate the server is running, correct me if i’m wrong:
2020-01-21T16:19:10.1736118+08:00 dbg: frontend Logging to C:\Users\USER_NAME\AppData\Local\Temp\Compute\Logs {}
2020-01-21T16:19:10.3734985+08:00 inf: frontend Configuration Result:
[Success] Name compute.frontend
[Success] ServiceName compute.frontend {“SourceContext”: “Topshelf.HostFactory”}
2020-01-21T16:19:10.3874905+08:00 inf: frontend Topshelf v4.1.0.172, .NET Framework v4.0.30319.42000 {“SourceContext”: “Topshelf.HostConfigurators.HostConfiguratorImpl”}
2020-01-21T16:19:10.4364624+08:00 dbg: frontend Running as a console application, creating the console host. {“SourceContext”: “Topshelf.Builders.RunBuilder”}
2020-01-21T16:19:10.4454586+08:00 dbg: frontend Starting up as a console application {“SourceContext”: “Topshelf.Hosts.ConsoleRunHost”}
2020-01-21T16:19:10.9401902+08:00 dbg: frontend ApplicationStartup {}
2020-01-21T16:19:10.9501846+08:00 inf: frontend Request stashing enabled via TempFileStasher {}
2020-01-21T16:19:11.1560693+08:00 inf: frontend compute.frontend running on http://localhost:8888 {}
2020-01-21T16:19:11.1590660+08:00 inf: frontend The compute.frontend service is now running, press Control+C to exit. {“SourceContext”: “Topshelf.Hosts.ConsoleRunHost”}
  1. However, I’m unable connect to local server by running the following in a web browser:
    http://127.0.0.1:8080/version
  2. and if I run the following, i got “Backend not available” shown in the web broswer:
    http://127.0.0.1:8888/version
Have I scrambled my local web server setting and system variables?
May I ask how to set up it correctly to access compute-rhino3d locally?
Thanks.
The frontend should spawn the backend process. I’d expect to see a log line like…
2020-01-24T16:20:03.7541948+00:00 inf: frontend Starting back-end geometry service on port 8080 {}
Did you configure any other environment variables, such as COMPUTE_SPAWN_GEOMETRY_SERVER?
I think I had similar problem and some how managed to make it work? Not sure though…
using the frontend~.exe files in
https://ci.appveyor.com/project/mcneel/compute-rhino3d/branch/master/artifacts
rather than from current github repo in rhino dev doc from
Also typed next code on powershell couple of times back and forth I have some how managed to get access to local server (which is actually not sure what I am doing)
netsh http add urlacl url=“http://+:8081/” user=“Everyone”
netsh http add urlacl url=“http://+:80/” user=“Everyone”
netsh http delete urlacl url=“http://+:8081/
netsh http delete urlacl url=“http://+:80/
netsh http delete urlacl url=“https://+:443/
Screenshot 2021-09-18 163733
Screenshot 2021-09-18 165253
but if I try to access using http://127.0.0.1:8081/ it doesn’t work
Screenshot 2021-09-18 164323
I changed the part of the code from
https://www.youtube.com/watch?v=XCkRXAEJMhg&t=2023s
to execute it and it kind of works.
But it requires me to press enter on prompt whenever I try to run on pycharm (seems like it is requesting my approval? I barely only know how to print hello world though… :sweat_smile:)
while doing that, I was also following method from this
https://developer.rhino3d.com/guides/compute/development/
If i just try to debug from visual studio, error message shows up
Screenshot 2021-09-18 170038
Assuming there is something missing, I had to find the exe file it’s asking for - which I could not find on the github repo.
Screenshot 2021-09-18 165945
So without knowing very much anything about how to read this files, I just blindly copied the files from here
And now I can some how enter the debug with out that message but it actually fails in the end.
Also the example file in here
the line example doesn’t work.
EDIT: if I change the data tree “{0;}” to the one that matches in the ghx it’s referencing it works.
