Unable to get the layer width
Currently I can’t get the layer width, I use a demo to show the problem
“layout.Size.Width” this method always returns a value of “-1”, why is that, I am very confused, I can’t get the real value
The problem :backhand_index_pointing_down:
import Rhino
import scriptcontext
import System
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
import Eto
drawing_Width = 400
drawing_Height = 200
drawing_Padding = 20
drawing_Spacing_Size_0 = 5
drawing_Spacing_Size_1 = 5
m_slider_Boolean_value = False
class Newwindow(forms.Dialog[bool]):
    """"Learning eto"""
    def __init__(self):
        super().__init__()
        self.ClientSize = drawing.Size(drawing_Width, drawing_Height)
        self.Title = 'New window'
        self.Padding = drawing.Padding(drawing_Padding)
        self.Resizable = True
        self.m_label = forms.Label()
        self.m_label.Text = 'd_cv'
        self.cve = forms.Button()
        self.cve.Text = "curve"
        self.DefaultButton = forms.Button()
        self.DefaultButton.Text ='OK'
        self.AbortButton = forms.Button()
        self.AbortButton.Text ='Cancel'
        drawable = forms.Drawable()
        drawable.Width = 20
        drawable.Height = 40
        layout = forms.DynamicLayout()
        layout.Spacing = drawing.Size(drawing_Spacing_Size_0, drawing_Spacing_Size_1)
        layout.AddRow(self.m_label , drawable)
        layout.AddRow(self.cve)
        layout.AddRow(self.DefaultButton,self.AbortButton)
        self.Content = layout
        #_________This👇
        print(layout.Size.Width)
def RequestRoomNumber():
    dialog = Newwindow()
    dialog.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
if __name__ == "__main__":
    RequestRoomNumber()
@curtisw Do you know the problem, Sir?
-1 means auto. If you haven’t set the width explicitly that’s what it returns
Didn’t the controls in the layer modify the “width”?
I’m using a custom draw and this code gets the width, but if you print it, it’s still going to print “-1”
rect_top_layout = ed.RectangleF(self.top_layout.Location.X,self.top_layout.Location.Y,self.top_layout.Width,self.top_layout.Height)
yes they change the actual width without setting it explicitly, hence the -1 / auto
If you set the width explicitly, or scale the window, you’ll get a value back that is not -1
Is there a way to get the actual “size” hidden by the layer? Because with controls there will be actual changes
I don’t think there is, no, but I agree it would be handy to have this.
RH-87086 Eto: report actual size of a control that is auto sized
There is no way to get the actual size of a control until it is loaded/shown. This is because the layout systems on both Mac and Windows/WPF is deferred. Otherwise, you can use GetPreferredSize() to get a control’s preferred size.
