Unable to calculate area / centroid
is this bug back?
What can I do? change things what is causing the problem?
Rhino doesn’t tell the problem.
can’t upload drawing because it’s a complete boat and I can’t share it
edward
Your curve might be open.
Is this in Rhino or Grasshopper?
it is in rhino 8
no, I only have surfaces (area)
Hi @E.O.Stam
Have you checked for bad surfaces?
If you still encounter “unable to calculate area” message after resolving or hiding bad surfaces I suggest you to:
  1. Select all Surfaces, explode eventual polysurfaces to simple surfaces.
  2. Select all Surfaces
  3. Export selected as Object Properties *.CSV
  4. Open Excel, go to Data \ Get & transform Data \ From Text/ CSV \ Load CSV
  5. Filter by Area, unselect all, then choose “blanks”
  6. If curves or other objects are in the file, filter and leave only surfaces on
  7. You’ll see a list of object with no area, probably due to some inaccurate or self-overlapping trimming contours.
  8. Browse to Object ID and copy it
  9. Go back to Rhino, type _SelID, then paste the ID you just copied from Excel
  10. Offending object will be selected
  11. Isolate this object and try to fix it by rebuilding or just untrim and trim again.
  12. Repeat this for all “no area” instances.
Unfortunately you have to repeat it for each ID, I dunno if there is some other way to script it or pinpoint NoArea surfaces without involving CSV…
This should resolve the NoArea issue.
I work with boats as well and I encounter this sometime when getting from outside dirty files.
Could be due to some translation error during import / export or different tolerance settings.
thank you Luca,
solved
I also have peters tools and did it with that plugin, 1 part was not oke.
so no bug in Rhino but a bad draftsman designer.
have a good day
Happy you solved it,
Peter’s Tools are great!
which comand have you used to fix this?
thanks!
bom
Bill of Materials and object data tools
