Turn multiple points on a gyroid surface into a graded density volume
I was able to plot a bunch of points on the surface of a gyroid. I am using the Dendro plugin to turn these points into a volume. One may ask why I made a gyroid surface, and then turned it into points and then into a volume. The reason is because I want to achieve a graded density over the length of the gyroid. I thought this would be easier using points, instead of a whole surface.
I can’t figure out how to assign different sizes to sections of points (each base cell dimension) in order to create a graded density (gradually increasing thickness) when I convert it into a volume.
Any suggestions would be greatly appreciated, or even a point in the right direction. Below are pictures to visualize what I am talking about, as well as the process in Grasshopper for reference.
Thank you,
Dylan
