Trying to make a chain
Looking for some tips on doing this correct.
I have a chain link as a closed polysurface and a curve.
I want to array along curve the link and rotate every 2nd link 90ª .
So I can get the object and copy and rotate it. What I am wondering is the array part. I don’t see any commands on the Rhinoscript syntax page.
Here is my script for rotating the object
def createLinks():
    obj = rs.GetObject("Select object to rotate")
    if obj:
        bb=rs.BoundingBox(obj)
        # find object's bounding box center point
        center=rs.AddPoint.Origin=(bb[0]+bb[6])/2
        # rotate and copy original object
        cplane = rs.WorldXYPlane()
        xform = rs.XformRotation2 (90.0, cplane[1], center)
        link2 = rs.TransformObjects( obj, xform, True )
    rs.MoveObject(link2, (2.75,0,0))
createLinks()
Would it be better to Array along curve first then rotate every second one with …
Slice notation a[low:high:increment]
For now I only have 4 chains to do, so a straight array and then flow along curve works manually for now.
I did see a script about dividing the curve into desired lengths or amounts and then moving object to that.
I will give that a try in a bit.
So I have this so far, but how to make multiple copies.
Here is a test Rhino file …
Chain test-1.3dm (209.8 KB)
crv1 = rs.GetObject("Select a curve")
     if rs.IsCurve(crv1):
    length = 2.18
    points = rs.DivideCurveLength(crv1, length)
    for point in points: rs.AddPoint(point)
obj = rs.GetObject("Select object to copy")
if obj:
start = rs.GetPoint("Point to copy from")
if start:
    end = rs.GetPoint("Point to copy to", start)
    if end:
        translation = end-start
        rs.CopyObject( obj, translation )
def rotateLinks():
    if obj:
rotateLinks()
Hi Randy,
I edited your script to make it work for all points on the division. I hope the comments are clear else ask for it.
    length = 2.18
    #points = rs.DivideCurveLength(crv1, length)
    #for point in points: rs.AddPoint(point)
    # get parameters on the curve to later use to get the frame on the curve
    parameters = rs.DivideCurveLength(crv1, length,return_points=False)
#set plane to copy from
startplane = rs.WorldYZPlane() #plane perpendicular or link orientation on curve
bbox = rs.BoundingBox(obj)
bbox_center = rs.PointDivide(rs.PointAdd(bbox[0],bbox[6]),2)# get boundingbox center
startplane.Origin = bbox_center #set startplane origin to center
#Links will be placed on the center of the division points
N = -1 # counter to check if we are at even link (even links are rotated)
#matrix to rotate around length axis 90deg
Xrotate = rs.XformRotation2(90,startplane.ZAxis,startplane.Origin)
#for each parameter (point on curve) transform the link to the point on the curve
for parameter in parameters:
    N+=1 #add 1 to object counter
    new_link = rs.CopyObject(obj)#copy original
    if (N % 2 == 0): #even number so we first rotate
        rs.TransformObject(new_link,Xrotate,copy=False)
    # get plane perpendicular on curve at parameter
    curve_frame = rs.CurvePerpFrame(crv1,parameter)
    Xoncurve = rs.XformRotation1(startplane,curve_frame)
    rs.TransformObject(new_link,Xoncurve,copy=False)
-Willem
Thanks @Willem, I need to understand basic Python more.
Thanks for the comments, they help.
Working on a recursion issue making seats for gems sized 1 -10, by 0.1 & 0.25mm
I need a week just to do python :smile:
