Trying to fix loft result
Hello!
I am trying to fix the loft result and the only thing I thought is to shift the list of points of one curve. However, I know that I have to do and something else with the lists in order to avoid this problem but I don’t know why.
shift list and loft.gh (17.5 KB)
Thank you!
I don’t understand, if you don’t use the shift, there’s no mistake… And you can perform the loft with the two initial curves…
there is a deformation on the corners if I loft with the two initial curves…this is a reason I used shift…
Is this what you want?
shift list and loft_re.gh (19.1 KB)
Man you are awesome…I really appreciate your help!
