Hi all,
I’m strugglin with this.
I have some surfaces, and i separate from them the surfaces with the edge smaller than x value. Then i want to join this small surface with the nearest surface next to it, and replace the joined surface in the old list.
I can have 3 possible cases.
case 1)
I have only one small surface, it could be work with this definition.
But in this case neither brep join nor solid union worked.
join surfaces.gh (109.2 KB)
case 2)
I have 2 small surfaces, one at start, one at the end of the list.
How would you do?
case 3)
I have no small surface.
In conclusion how would you do a solution that satisfy all 3 cases? Is it possible?
Thanks
