I’m trying to work with Alberic Trancart’s script for converting a Karamba-model to a .dat file (readable by Sofistik).
The original code is a bit out-dated, as it was last updated in 2014, and I was trying to make it work for the newer Karamba build.
However, I get the following error-message:
[A]Grasshopper.Kernel.Data.GH_Structure`1[Karamba.Models.GH_Model] cannot be cast to
[B]Grasshopper.Kernel.Data.GH_Structure`1[Karamba.Models.GH_Model].
Type A originates from 'Grasshopper, Version=1.0.0.20, Culture=neutral, PublicKeyToken=dda4f5ec2cd80803' in the context 'LoadFrom' at location
'C:\Program Files\Common Files\McNeel\Rhinoceros\5.0\Plug-ins\Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)\0.9.76.0\Grasshopper.dll'.
Type B originates from 'Grasshopper, Version=1.0.0.20, Culture=neutral, PublicKeyToken=dda4f5ec2cd80803' in the context 'LoadFrom' at location
Somehow it seems I’m trying to cast from and to the exact same location.
Does anyone have an idea what’s going wrong?
Could it be that you’re loading that assembly twice, from two different locations? If you search your entire computer for all instances of that dll or gha file, how many hits do you get?
Another reason could be that the COFF loading is giving you grief. Try GrasshopperDeveloperSettings and switch COFF loading off. Then restart Rhino and Grasshopper and see if that makes a difference.
Hey thanks for the reply!
I tried this already, the problem maintained an the extra problem occured that the Karamba “line-to-beam”-component didn’t work anymore…
I do find two instances of the grasshopper.dll.
One in “C:\Users\907623.nuget\packages\grasshopper\0.9.76\lib\net35”
and one in the usual common files “C:\Program Files\Common Files\McNeel\Rhinoceros\5.0\Plug-ins\Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)\0.9.76.0”
If I check the references in visual studio, I see the reference to grasshopper.dll once with one path.
Set all the copy local to false, deleted the duplicate instances of the .dll, problem still occurs…
I guess there’s something wrong in the code? This is the code where I guess something would be wrong then:
// Karamba To Sofistik component for GrassHopper
// Convert a karamba model to a .dat file readable by Sofistik
// Git: https://github.com/AlbericTrancart/karambaToSofistik
// Contact: alberic.trancart@eleves.enpc.fr
using System;
using System.Collections.Generic;
using System.IO;
using Grasshopper.Kernel;
using Rhino.Geometry;
using Karamba.Models;
using Karamba.Elements;
using karambaToSofistik.Classes;
namespace karambaToSofistik {
public class karambaToSofistikComponent : GH_Component {
// Component configuration
public karambaToSofistikComponent() : base("karambaToSofistik", "ktS", "Converts a Karamba model to a .dat file readable by Sofistik", "Karamba", "Extra") { }
// Registers all the input parameters for this component.
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager) {
pManager.AddParameter(new Param_Model(), "Model", "Model", "Model to convert", GH_ParamAccess.item);
pManager.AddTextParameter("Path", "Path", "Save the .dat file to this path", GH_ParamAccess.item, @"");
// Registers all the output parameters for this component.
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager) {
pManager.Register_StringParam("Output", "Output", "Converted model");
pManager.Register_StringParam("Status", "Status", "Errors or success messages");
// We need to register all groups defined in Grasshopper
static public List<string> beam_groups = new List<string>();
// This is the method that actually does the work.
protected override void SolveInstance(IGH_DataAccess DA) {
// Some variables
string output = ""; // The file output
string status = "Starting component...\n"; // The debug output
// Several arrays where the data is stored
List<Material> materials = new List<Material>();
List<CrossSection> crossSections = new List<CrossSection>();
List<Node> nodes = new List<Node>();
List<Beam> beams = new List<Beam>();
List<Load> loads = new List<Load>();
// We need to reset some variables because the objects are not freed until Grasshopper is unloaded
Parser.id_count = 1;
try {
// Load the data from Karamba
// Retrieve and clone the input model
GH_Model in_gh_model = null;
if (!DA.GetData<GH_Model>(0, ref in_gh_model)) return;
Model model = in_gh_model.Value;
model = (Karamba.Models.Model) model.Clone(); // If the model is not cloned a modification to this variable will imply modification of the input model, thus modifying behavior in other components.
if (model == null) {
status += "ERROR: The input model is null.";
output = "Nothing to convert";
else {
string path = null;
if (!DA.GetData<string>(1, ref path)) { path = ""; }
if (path == "") {
status += "No file path specified. Will not save data to a .dat file.\n";
// Retrieve and store the data
// Materials
foreach (Karamba.Materials.FemMaterial material in model.materials) {
// The first material seems to be wong but I don't know why it exists
if(model.materials.IndexOf(material) != 0)
materials.Add(new Material(material));
/*Disabled for forward compatibility
// Check for material duplicates
// This is necessary because karamba uses a preset material that is added every time that a model is assembled
// As a consequence a model can get a great amount of redundant materials that will flood the output
// Furthermore karamba seems to create a buggy material at index 0 during the cloning operation
materials.RemoveAt(0);
// Using a for loop because a collection used in foreach is immutable
for (int i = 0; i < materials.Count; i++) {
materials.RemoveAll(delegate(Material test_material) {
return test_material.id != materials[i].id && materials[i].duplicate(test_material);
status += materials.Count + " materials loaded...\n";
// Cross sections
foreach (Karamba.CrossSections.CroSec crosec in model.crosecs) {
crossSections.Add(new CrossSection(crosec));
// The same happens with Cross Sections
crossSections.RemoveAt(0);
for (int i = 0; i < crossSections.Count; i++) {
crossSections.RemoveAll(delegate(CrossSection test_crosec) {
return test_crosec.id != crossSections[i].id && crossSections[i].duplicate(test_crosec);
status += crossSections.Count + " cross sections loaded...\n";
// Nodes
foreach (Karamba.Nodes.Node node in model.nodes) {
nodes.Add(new Node(node));
status += nodes.Count + " nodes loaded...\n";
foreach (Karamba.Supports.Support support in model.supports) {
nodes[support.node_ind].addConstraint(support);
status += "Support constraints added to " + model.supports.Count + " nodes.\n";
// Beams
foreach (Karamba.Elements.ModelElement beam in model.elems) {
Beam curBeam = new Beam(beam);
// Adding the start and end nodes
curBeam.start = nodes[curBeam.ids[0]];
curBeam.end = nodes[curBeam.ids[1]];
beams.Add(curBeam);
status += beams.Count + " beams loaded...\n";
// Loads
foreach (KeyValuePair<int, Karamba.Loads.GravityLoad> load in model.gravities) {
loads.Add(new Load(load));
status += model.gravities.Count + " gravity loads added.\n";
foreach (Karamba.Loads.PointLoad load in model.ploads) {
Load current = new Load(load);
current.node = nodes[load.node_ind];
loads.Add(current);
status += model.ploads.Count + " point loads added.\n";
foreach (Karamba.Loads.ElementLoad load in model.eloads) {
// Create a load variable base on the load type
Load current = new Load();
Karamba.Loads.UniformlyDistLoad line = load as Karamba.Loads.UniformlyDistLoad;
Karamba.Loads.StrainLoad pret = load as Karamba.Loads.StrainLoad;
Karamba.Loads.TemperatureLoad temp = load as Karamba.Loads.TemperatureLoad;
if (line != null) {
current = new Load(line);
// Very important to check Temperature BEFORE Pretension becaus Temperature derivates from Pretension
else if (temp != null) {
current = new Load(temp);
else if (pret != null) {
current = new Load(pret);
// If there is not target element, apply the load to the whole structure
if (load.beamId == "") {
current.beam_id = "";
loads.Add(current);
else {
// We search the element
current.beam = beams.Find(delegate(Beam beam) {
return beam.user_id == load.beamId;
loads.Add(current);
status += model.eloads.Count + " line loads added.\n";
// ID matching
// Karamba and Sofistik use different ID systems
// Karamba's materials and cross sections are pointing to an element ID
// Sofistik's elements need a cross section ID which needs a material ID
foreach (Material material in materials){
// If the IDs list is empty, it means that we want to apply the material to the whole structure (whichi is the default behavior: the default material is set by the constructors of all elements)
bool test = false;
foreach (string id in material.ids) {
if(id != "")
test = true;
if (test) {
foreach (CrossSection crosec in crossSections) {
if(material.ids.Contains((crosec.id - 1).ToString()))
crosec.material = material;
status += "Matching with material IDs...\n";
// If the IDs list is empty, it means that we want to apply the cross section to the whole structure (which is the default behavior: the default cross section is set by the constructors of all elements)
bool test = false;
foreach (string id in crosec.ids) {
if (id != "")
test = true;
if (test) {
foreach (Beam beam in beams) {
if (crosec.ids.Contains((beam.id - 1).ToString()))
beam.sec = crosec;
status += "Matching with cross section IDs...\n";
// Write the data into a .dat file format
Parser parser = new Parser(materials, crossSections, nodes, beams, loads);
output = parser.file;
if (path != "") {
status += "Saving file to " + path + "\n";
System.IO.File.WriteAllText(@path, output);
status += "File saved!\n";
catch (Exception e) {
status += "\nERROR!\n" + e.ToString() + "\n" + e.Data;
// Return data
DA.SetData(0, output);
DA.SetData(1, status);
// Icon
protected override System.Drawing.Bitmap Icon {
get { return Resource.Icon; }
// Each component must have a unique Guid to identify it.
public override Guid ComponentGuid {
get { return new Guid("{1954a147-f7a2-4d9c-b150-b788821ccae7}"); }
Another question. How are you referencing karamba? Is it a .gha that you renamed as a .dll (since visual studio won’t accept .gha the normal way). I also had the same error as you when I referenced a .gha that I renamed to a .dll for visual studio to reference. AlI the methods worked as .dll but I got that [A]cannot cast to [B] error. I had to force visual studio to reference the .gha via the text editor and then that error went away (for me I was referencing grasshoppers transform.gha)
are you completely sure COFF loading is turned off in GrasshopperDeveloperSettings? In my experience with these kinds of type issues this is the culprit 95% of the time.
Which service release of Rhino do you have installed?
I’ve noticed that Karamba isn’t built against say SR0 of Rhino, so maybe it’s a nested rhinocommon type reference that is triggering this error. If you update to the latest SR it might resolve the issue.
I did update references (as newer versions of Karamba have breaking changes from the code as on github), but the open source project did compile, load and work correctly here for me.
As an alternative, I do provide Karamba to Structural analysis components (Sofistik included). You can download from http://www.geometrygym.com/downloads My tools aren’t open source though, and I do charge commercial users to use them (after a free evaluation).
Thanks, I’m aware of your tools, they’re great. However I would like to make it as easy as possible for other people to use this. Using one component to convert the Karamba-model to a .dat file seems really handy, especially for quick variant studies.
But I guess the problem lies in what Michael said, referencing a renamed .gha instead of the actual .gha.
That’s what I’m offering, a Karamba to .dat component. Refer to image below.
You can also generate independent model data with my plugin to combine in (such as load case combinations)
I renamed a copy of the .gha back to .dll for referencing in visual studio. You need to ensure that the karamba plugin is loaded prior to yours (which I do by a skeleton dll for the grasshopper component which references a separate dll to do the conversion).
Ah that does look quite good! Is it compatible with Karamba 1.2.2 as well? I downloaded the plugin to have a look, however, it gives the error that it can’t find Karamba 1.14.0.0 (no wonder, cause I don’t have it installed )
Next to that, I would still like to fix my initial problem
I’ll email you a direct link (as if I post here it will be broken in the future) but I did update the download link today, http://www.geometrygym.com/downloads ) Putting your code onto a fork would allow myself or others to try and replicate the behaviour you see. You must have made other changes as the github repo you linked is built against old karamba versions that have breaking changes with current. I do also support Karamba 1.3.x
I first completely un-referenced the reference from VS so that I can add the entire reference manually rather than changing the path (path change didn’t work for me). Then I located the .csproj file.
Right click that and open in notepad or any editor you prefer.
Scroll down to the section where you see the other references like RhinoCommon and Grasshopper.
The manually add the new reference for your gha.
