Version:
Version 8 SR22
(8.22.25196.13001, 2025-07-15)
Commercial
Surface Trim Issue.3dm (177.1 KB)
There may be a possible bug or additional code that need to be implemented to make trimming curved surfaces actually work. Can someone tell me how to trim a curved surface in this file by simply selecting the cutting surface?
When trimming rectangular objects, Rhino works perfectly like this…
Now let’s look @ trimming this area:
If I select the surface that will be the trimming/cutting object like this:
and select the object where the arrow is, NOTHING HAPPENS.
However, if I select the surface edge of the previously selected trimming object rather than the surface itself, the trim works perfect.
Why is this? It should not matter if I select the surface edge versus the surface itself. I realize that if I select a surface for trimming, Rhino might only trim if that surface is completely within another surface. Is this how Rhino is supposed to work?
If so can there be a feature request where if the edge of the selected surface is used for trimming and it’s against another surface then Rhino will trim the selected surface?
If not, then it seems like this is a bug.
