This has been discussed to some length in the newsgroup (creating trimmed BReps from surface and (u,v) trim coordinates), but I would like to know if there are some examples for RhinoCommon to create a trimmed BRep from scratch.
For Rhino_DotNet there are examples to do this at http://en.wiki.mcneel.com/content/upload/files/BrepSamples_net.zip
I have tried to follow these samples and reproduce them in RhinoCommon, but so far no luck. I get stuck when setting vertex indices on loops or edges IIRC.
A similar example in RhinoCommon, creating a planar face with a hole, and a trimmed face would be much appreciated.
@dale I remember you had me add some functions to RhinoCommon for this functionality, but don’t quite remember where we got with this. Do you have a working sample, or is there more that I need to add to the SDK?
I have upgraded to SR7 today and tried to port my Rhino_DotNet code to RhinoCommon. I still find some functionality lacking in RhinoCommon that I am using from Rhino_DotNet. But, maybe I’m doing things wrong.
What I would really appreciate is an example in which trimming a surface is performed when a list of trim (U,V) coordinates is known. This list of parameter space coordinates is one closed loop, which may contain sharp bends in Cartesian space.
I suppose it is similar to how IGES bounded entities (IGES 141) and bounded surface trims (IGES 143) are defined.
Hey @menno,
Can you send me some of your older Rhino_DotNet code that does this (private email is fine)? I don’t have a sample ready and this would help me find whatever spots are missing from the SDK.
Thanks,
-Steve
