Hi, I have a little problem with the command ‘Delaunay Mesh’ and ‘Delaunay Edges’.
I created a geometry in Rhino and transfered it into Grasshopper. Then I created with the command ‘Populate geometry’ some points on the geometry.
Now I tried to connect the points with the command ‘Delaunay Mesh’ to a triangle mesh.
The output I received is shown in the following picture.
The triangle got just acute angles and the points are connected also inside the cylinder.
How can I solve this problem?
