Just getting started in Rhino3dm.js (and Javascript for that matter), and running into the following error when I try to define a simple rotation Transform:
Uncaught (in promise) BindingError {name: “BindingError”, message: “function Transform.rotation called with 4 arguments, expected 3 args!”
my code is just:
let rotationTransform = rhino.Transform.rotation(Math.sin(rotation_angle), Math.cos(rotation_angle), axis_vector, pt1);
I’ve used the RhinoCommon version of this Transform plenty of times, and the docs are pretty clear that there are 4 args required, not 3…
FYI, the value of the args are as follows:
Math.sin(rotation_angle) = 0.17410813759359597
Math.cos(rotation_angle) = 0.9847265389049334
axis_vector = [0, 0, -0.5]
pt1 = [0.0000016560283029321, -0.0000016561149323024438, 144.37180070758296]
I know I’m missing something obvious here… Any idea what’s going on?
That did help. I also realized I had to add the “new” keyword. So my code now looks like:
let rotationTransform = new rhino.Transform.rotation(rotation_angle, axis_vector, pt1);
However, as soon as that was fixed I realized that Transforms are not applied to objects the same way as RhinoCommon. For instance, I have a mesh object called “tube” and I was trying to apply the Transform like this:
tube.Transform(rotationTransform);
but realized the correct way to apply it in JS is like this:
tube.rotate(rotation_angle, axis_vector, pt1);
Can you help me understand why things work so differently in Rhino3dm.js, and why I would want to create a Transform object if I’m just going to explicitly define it as part of the .rotate() method?
I just updated the javascript docs. There was a bug in the documentation generator that was not picking the appropriate matching RhinoCommon function to use for filling in the description on a javascript function
